Timer på recirkulation
Indlægaf Kingo » ons jun 12, 2013 19:47 pm
Er der nogen der ved hvilke MY'ere dette gælder for:
TNN87-40-2001-10-05 Title: Climate Control Module Recirculation Timer Function.
This information is intended to assist in better understanding the Recirculation Timer Function found in the Climate Control Module (CCM) in these models. The CCM has two recirculation modes: normal and timed. In normal mode, when the recirculation * is pressed, the system recirculates the interior air until the driver takes further action. In timed mode, when the recirculation * is pressed, the system recirculates air for 5 to 12 minutes, depending on outside air temperature, and then reverts to fresh air. Timed mode eliminates the need to manually revert to fresh air by pressing a *.
Note: Vehicles equipped with the Interior Air Quality System do not have the timed recirculation mode.
ACTIVATING/DEACTIVATING TIMED RECIRCULATION MODE S/V/C70 Vehicles: With the key in position II, press and hold the Recirculation * for three to five seconds.
- If both the green fresh air and amber recirculation * LEDs begin flashing, you are entering "timed" mode.
- If both LEDs shine steady, you are exiting "timed" mode.
Mode Memory: If the vehicle is switched off while recirculation timer mode is active, timer mode will still be active when the vehicle is restarted.
I øvrigt fundet på denne side med mange fine beskrivelser over kendte fejl :http://v70r.com/forums/topic/2025-technical-bulletin-reference/
Re: Timer på recirkulation
Indlægaf ptheo » tors jun 13, 2013 2:21 am
Det er standard i en V70-MY2007 produceret i Sverige i marts 2007.....
Vadis-Vida-DiCE.....
ptheo
Tilmeldt: tors apr 05, 2012 13:28 pm
Geografisk sted: 9670 Vesthimmerland
Indlægaf Kingo » tors jun 13, 2013 16:42 pm
Prøvede lige min - og kan få recirc knappen til at blinke ved at holde den inde- havde ikke tid til at se om det gav timer funktionen.
Indlægaf Claus » ons jun 19, 2013 1:22 am
Tryk på denne kontakt for at aktivere recirkulation (luft i kabinen recirkulerer - ingen frisk luft ind i rummet). Dioden i kontakten lyser for at angive, at funktionen er aktiveret.
Brug denne funktion, hvis udeluften er forurenet med udstødningsgasser, røg, osv. eller til at opvarme / afkøle bilen hurtigt.
Recirkulation bør ikke anvendes i mere end 15 minutter. Hvis dine vinduer begynder at tåge eller dis, sørge for, at recirkulation funktionen er slået fra.
Valg Defroster automatisk recirkulation fra.
Timerfunktion: (Biler med Interior Air Quality-systemet har ingen timerfunktion) trykker og holder nede i mindst 3 sekunder aktiverer en timer funktion. Den dioden i kontakten blinker i cirka 5 sekunder. Recirkulation vil derefter altid opererer i perioder på 5 til 12 minutter, afhængig af den omgivende temperatur, hvorefter den slukker automatisk. Ved at trykke på knappen på ethvert tidspunkt under recirkulation periode frakoble funktionen og tillade frisk luft ind i kabinen. Tryk og hold på kontakten igen i mindst 3 sekunder for at vende tilbage knappen til sin oprindelige funktion (dvs. vil recirkulation forblive på indtil den slukkes).
Jeg fandt den bare på dansk det forstår jeg lidt bedre.
Min er med Air Quality-systemet så den blinker ikke.
