To finish off the electrics, I stole the reverse switch connector from the donor car and spliced it into the appropriate auto box connector pins. I also jumpered it so it would always think it was in Park or Neutral thus allowing the starter motor to fire. More on this later... I used glue and cable ties to secure these wires in place - et voila, no auto box ECU required any more, and no gearbox warning light.
