annullering af servicelamper Volvo 850 / 1992
Indlægaf 850sport » fre sep 05, 2014 19:18 pm
annullering af servicelamper - hvordan slukker jeg dem, har hørt at man skal tage +ledning af batteriet - er
der ikke andet og gøre ? . Alt er ordnet på vognen men lamperne lyser ? -
Volvo 850 2.5 / 1992 hilsen Jean
Jeg fik da også lige skrevet det så var der et Gogle-forslag
RESETTING 5000 MILE SERVICE LAMP ON 1994 + 1995 850
NOTE: This function is for the service reminder lamp, be sure you have performed the proper service such as changing the oil before resetting. If the check engine lamp is illuminated when the car is running, you'll need to have the car looked at by the Volvo dealer for proper diagnosis.
1. Turn on the ignition to the KPII position so the warning lamps on the dash are illuminated. Do not start the car.
2. Open the bonnet of the car and locate Diagnostic test port (A) behind the driver side headlamp.
3. Remove the cover and pull the jumper wire out of the holder in the cover.
4. Insert the jumper into terminal #7, then press * 4 times, wait approximately 5 seconds and the red lamp should glow continuously. You are now in the data reset mode.
5. Press the * 1 time and wait approximately 5 seconds for the lamp to glow again then press the * 5 times. After about 5 seconds the lamp will illuminate again, press the * 1 time and you will see the lamp flash repeatedly for a couple of seconds indicating that the service lamp has been properly reset.
6. If a mistake is made, simply switch the ignition off and back on to reset and start over.
850sport
Tilmeldt: tirs jun 10, 2014 13:07 pm
Re: annullering af servicelamper Volvo 850 / 1992
Indlægaf Pede66 » fre sep 05, 2014 20:36 pm
Indlægaf 850sport » lør sep 06, 2014 10:12 am
Det virkede bare - utroligt- men dermed er det så ikke slut - der er jo andre lamper
i mit tilfælde er der også den ved siden af - Malfunction indicator lamp - den kom i funktion
pga krumtap sencor var defekt - det er ordnet men værksted har heller ikke nulstillet den.
Spørgsmålet er om jeg bare skal gøre det samme igen med hul #7 ??????
et måske sidste spørgsmål - hvad er de andre huller til 1-2-3 og 5-6 ??????????
hilsen Jean og ellers tak for hjælpen
850sport
Indlægaf Pede66 » tirs sep 09, 2014 7:11 am
